Good evening,
I'm typically a glass half full type of guy but I must say I'm livid after buying this brake upgrade kit and curious if others have had the same issues.
I have an early 72 pre-L and just spend $4200 on the kit. So far, I've had to make .250" bracket spacers in addition to the included spacers to get the e-brake to work.
I moved onto the front this evening and found that the rotors have a clearance issue with the factory backing plates on the spindle. I'm hoping that I can just remove them, and all is good.
I have an email into Scott, but he won't be very happy with my feedback and doubt I will get a response.
I haven't got to the master cylinder and brake line plumbing yet, so I expect more of the same fitment issues.
At this point, I would not recommend this kit.
Thanks,
John
#2551
