Also, don't be afraid of torquing the axle nut really tight!. I checked the SAE  for torque notes and that size nut in mild steel strips at around 1200 ft-lbs! So I use 400-ft-lbs on my axles. A long time ago I bought a two-piece 0-600 ft-lb Snap-On torque wrench for this and other outrageously tight  jobs. Found on E-bay cheap 'cause you don't use them often. Weighs 12 lbs.
Thanks for the info.  I've had the nuts off once and know about the L and R threads.  The RF spindle actually has left-handed threads too.
I will hold off on the Loctite since it doesn't seem to be used for this job.
I took the axle nuts off with the Milwaukee impact with no problem the first time.  I was thinking I could use the impact first and then go back at it with my 600lb torque wrench.  I'm not as strong as I used to be so hopefully the 4ft wrench will give me enough leverage.
I have a fixture setup using the original hubs.  Hoping to put the wheel studs thru it and tighten the lug nuts the back side.  Just hoping the vice will hold everything.
Thanks,
John
@jwelch68 posted:
Does anyone have an opinion on using an impact on the nut?  I have Milwaukee 1/2 drive that specs 450ft/lbs fastening torque and 650lbs busing torque.
I've done quite a few for one vendor and that's how we do them, crank the air up to 150 psi and use a high torque impact wrench. You can actually audibly here the sound change once it's fully seated and tight.
