Can anyone post photos of your Wilwood EPB installation? Particularly the routing of the wiring harness at the calipers and the engine bay. Thanks.
After looking at it some more, I might be routing the harness for the calipers with the same route as the rear side marker wiring. This avoids running a new harness along the bottom of the car.
It looks like the switch for the EPB will get mounted where the cigar lighter currently lives. It looks like the Wilwood engineers designed it that way.
Your thoughts on the harness routing and switch placement?
You may be aware of the routing of the taillight harness in the wheel well to clean up the engine bay…. Maybe you want to consider doing that, and routing the EPB wiring there as well, and just come through the marker light sleeves as needed to get to the calipers?
Yes, that is my thinking. The taillight harness is already rerouted out of the engine bay and into the passenger wheel well. The new EPB harness would piggyback on that.
Steve, as an alternative, you could mount the EPB switch in the hazard light switch location then relocate the hazard light switch to the cigar lighter location. You want to avoid any possibility of the EPB’s being activated accidentally and a curious passenger could create a very unsafe situation.
I mounted a Honda Starter button in the hazard light switch location and was surprised to find the hazard light switch fit perfectly in the cigar lighter hole.
I recently finsihed installing the Wilwood EPB. I installed Recaro seats and Kirk Evans bulkhead reduction kit. I had to remove the handbrake, there was no other way. The Wilwood Electronic Parking Brake seemed like an obvious solution. I mounted the Wilwood ECU on the firewall, passenger side, next to MSD-6AL and Tach Adapter. Its getting crowded back there.
I didn't have to modify the wiring harness at all. In fact I coiled up some of the extra length and may shorten it later. I ran the switch wires along the AC lines behind the passenger seat and to the ctr console. They are just long enough to place the switch in the cigar lighter hole.
I also spent far too long trying to get the dash light to come on when the parking brake was set. The Pantera uses the handbrake to pull the dash bulb low, which is not the case in the installation instructions (provides +12). Rather than rewire the light under the dash I used a second automotive relay to pull the original wire to ground.
Now I've lost my cigar lighter and wish I could trickle charge it through the lighter again.
JJones,
Are your mounting brackets for stock sized rear rotors?
The brackets change size depending on the rotor diameter and thickness. Each combination may produce a different bracket. I supply the drawing as a starting point. I 3D printed the bracket a few times until I was happy. Had them machined once. The previous owner did the initial Wilwood rotor conversion, I don't have the docs.
A few more pics for the OP, routing wire on driver's side. I used one zip tie to the SS brake cable. Now I'm sure someone is going to give me 10 reasons not to do that. If you have a better idea, please share your pics.
The bracket was designed for 11.75” dia x 0.71” thick rotors. - JJ
@davidnunn posted:Thank you for the information. BTW, you probably meant 0.71” thick rotors.
I did. I made the edit. Thank you, J
All good info and photos. It is much appreciated.
