Besides what was already posted, the 351 Windsor block is wider so regardless of whether the 351C heads are bolted on (they will fit), your 351C headers will interfere with the rear springs/shocks on both sides and the gas tank on the drivers side. Fixing these problems (with a welding torch) will cause interferences in the muffler exhaust pipes which then must both be corrected.
