He also found some Racing fluid for the brakes and clutch. (Not sure where?)
Made some progress on parts at home for re-finishing.
One muffler stripped...one to go.
Spreader bar before.....
Spreader bar after rough stripping...more to follow with this piece...
Got the tires from Larry mounted today and test fit them.
What do you think for a "Narrow Yellow" car?
Side View.
rear View
Fronts VS. rear.
What Size are the rears I have 295 50 15 Toyo's I did not have to roll the fenders but I did anyway before I painted the car. Nice keep the pictures coming.
I believe they're 305/50/15s. and are still available.
Thanks for the comment on the picture.
More to come soon. Got to get her back together soon!
George
George
Latest update! We've been busy, because we're so close to "Driving Time" we're finding more stuff to do. Go figure.
Larry set in a pair of his valve covers to cover the heads while cleaning things up a bit. I think he did a great job. I did the black paint last wekend, but the battery in my camera died. More pics to follow.
Larry re-engineered all the ignition wiring and added relays. Shoulf make the starts on "Cool' NH mornings alot better! Plus easier to troubleshoot problems if I have any.
New shocks are mounted.
Rear.
Rear.
Front.
one of the "New" issues we found was the radiator was leaking. Took it out and trying to find a local shop to fix it for a reasonable price. Last quote was 750!!!!! If anyone has a spare kicking around, let me know.
A little overspray here and some clean up to do, but that's done now and will be on the next post.
At least Larry finished up the wiring and the dash is put back together! Except for my Kenwood CD player that I have at home to replace the ribbon cable for the faceplate.
More to come soon! Got the half shafts, exhaust, carb, valve covers and spreader bar to finish re-finishing.
George
George
Busy day yesterday wrapping up some small details. We're getting close to the finish, which is good because the weather is getting nicer.
My wife is almost done adding some color to the carb and valve covers.
While I've been busy sorting out a messed up Kenwood CD player.
Finished the half shafts, spreader bar and A/C fan shroud.
This works was completed last week, before the battery in my camera died.
Another from last week.
Radiator area cleaned up.
Repaired radiator. Thanks to Larry, found a place local that did all the work for less than $225.00
Most of this weekend was the detail work around the ZF and engine.
A/C shroud.
ZF and shift linkage.
Spark plug wire loom kit to be installed after my valve covers are done.
Thankfully there is only a few things left to do on the "Have to Do" list. Then I'll be out running and helping Larry on his next project.
Got a few more items off the list this weekend. Still waiting for the last parts to come back from powder coating. If everything falls in line, may have her fired up next weekend!
Radiator repaired and re-installed.
Water tubes cleaned up and hoses replaced.
New stainless vent tube for the ZF installed.
New clutch slave line against original line.
New line installed. Slave going on next weekend after re-build.
Cleaned up the starter and re-installed.
Half shafts re-built and installed.
Last one this weekend. Hope to finish up next weekend!
Powder coating is finished!
Overflow Tank.
Overflow Tank.
Swirl Tank.
Exhaust done with High Temp coating.
