Originally posted by ehpantera:
I have just removed the wiper grills and found that putting a bit of penetrating oil in the corners and along the edge where the wiper shaft is helps in the removal process. I also used a paint can opener to pry up between the grill and the body.
Mark
5481
5461
Good to hear it came out ok not broken. I like your paint can opener devise for putting between the grill and metal of the car. On my red car I used a little plant hanger hook and that worked fine too (I suppose just about anything with a small hook on it would work). Also I put some strong string through some of the grill portions and pulled slightly upward on them while using the hook as well. Just got to be careful not to break the grill by pulling or prying too hard in any one spot.
