I'm going to use an electronic ignition system (Ford EDIS) with a 36-1 trigger wheel controlled by my EFI system. I then have no use for the distributor except for driving the oil pump but I don't want anything to stick up from the distributor hole in the block. Is this part already invented or is it possible to cut a distributor off?
