What does a basic refreshening for a ZF cost? If a synchro is needed, what does it add to the cost? What actually does a basic refreshening entail? Thanks.
Michael
quote:Originally posted by Cyboman:
Thanks, lpb.
I've already started the fattening proccess of my piggy bank!
Michael
Thanks for the input guys. I'm scared.
Michael
quote:Originally posted by Dougo:
Cyboman,
I had Lloyd do my trans last year. A couple synchros, bearings for the diff. (the car was driven 5 times in 15 yrs. the original bearings had seated themselves into the races)gasket set, safety wire. Basically cleaned it up. One month down time and $2400. As I left the shop he said "Your good for another 30 yrs". The trans works great. It shifts very postive, but I think my linkage / trunion bearing might need some fine adjustment.
quote:Originally posted by Coz:
...Heck, if I had your money, I'd throw mine away.....
I hear ya, Jim. I have no one over here to walk through it with me. That's never stopped me before, and may not this time, but this isn't just any manual trans. The ZF is a very expensive box to be blindly learning on!
It would be nice to live closer. I like to get out and help others with their Panteras as well as work on my own. The nearest Pantera 'enthusiast' to me is hours away!
Michael
quote:Originally posted by dean:
i'm calling you (coz) next year when i pull out my tranny.
quote:Originally posted by 4NFORD:
Hey Coz! You sing a different song now that your's is done! As I remember, you were fretting like the rest of us when it was broke!
BTW, what clutch and flywheel did you use?
quote:Originally posted by andriyko:
Coz,
You said you overhauled the ZF yourself. I was considering doing the same thing.
I have the ZF overhaul manual and it calls out for some special tools to do the job. What specific tools did you use?
B. Goyaniuk alias "andriyko"
Coz,
If you still have the holding jig, and it's easily accessible, can you take and post a picture of it so we can get an idea of what to build? Thanks.
Michael
quote:Originally posted by rlee63a4:
Coz, Any chance you have play-by-play pictures of the disassembly and assemby for future reference and repair? All it takes is a little insight to build up the courage to dive in to a project like that.
Ron
Can you post a parts and cost list and source so we can get an idea of what the cost replacement is for certain parts
What is the difference between using undersized synchros vs. normal sized ones? Is it to compensate for other worn components?
