Hi All;
My 72 has a noise coming from what it seems is the bell housing. Its a grinding rattling noise that increases with the RPM. I am running a stock clutch and an adjustable throwout bearing form PIM. This is my first Pantera but I don't think this is a normal noise. I have even taken the throwout bearing out completely and run the setup while the car is on axle jacks and noise is still there. The car was just put back together. I bought it as basket case with everything apart.The drive train has been sitting around for about 8 years without being run. Any help will be appreciated
You may have the wrong bolts installed, the two that attach the bell housing to the ZF (at the bottom from inside the bell housing). They should be allen head cap screws without any washers. Use blue loctite.
John
  • ZF_Bolt
Msgt, there are two different throwout bearings; one is a rather loose fit on the cast iron carrier while the other has an extra piece of sheet-steel folded into the opening. So this one is slightly tighter fitting. In addition, the anti-rattle spring for the bearing & carrier must be assembled such that it holds the bearing to the carrier. If you have the 'loose' type bearing and the anti-rattle hairpin spring is missing or assembled wrong, vibration will shake the bearing around a little. A sensitive person in a Pantera with stock exhausts may be able to hear the noise. if this is what's happening, it will cause no problem. Diagnosing 'funny noises' in a car is difficult enough when you're right there so my guesses may not apply.
