I'm looking for advice in installing an oil cooler for my ZF.
Mark
quote:Originally posted by Push1267:
I'm interested as well.
Sometimes (that's what I have seen and will consider doing for my car) an electric pump is used that pull oil from the speedo gear hole, though the pump and back through a pipe in the casing just over the ring and pinion, such that the rings gears are cooled directly (that must be the thinking). That of course, means drilling the case and welding a fitting to it.
Mark
I don't have a temp reading but you can't put your hand on it.
quote:Originally posted by JFB #05177:quote:Originally posted by ehpantera:
I have found this method pretty acccurated. If I can monetarly touch twice and have no problem doing a third touch, the temp is under 160F.
(method used to determine if water is hot enough to scald a hog)
I promise to get a specific reading in Sept. after SSCC.
quote:Originally posted by Bosswrench:
I really think you're worrying about a non-problem in a 30 minute event.
quote:Originally posted by comp2:
When I built my car I made provisions for a trans cooler. I am not driving in a way I need it now but it would not take much to finish the setup.
First I removed the A/C. I don't use A/C even in summer....what can I say, skinny guy who loves the wind in his face. The A/C saved 100+ lbs. The cooler went in the A/C location. I have a Tilton pump on the shelf ready to install. I have relays for the fan and the pump installed on rear firewall.
Fan is hooked up and can be useful to evacuate air from rear engine area. I have a trans temp gauge installed on the dash.![]()
If I am not going to use it right now I just need to plug the cooler so the mud dobbers don't block it.
quote:Originally posted by pantera chris:
2 questions, 2.) What is the Ford/Pantera tin for?
You want the fan to draw air in not push out.quote:Originally posted by comp2:
I presently have the fan blowing out which is hooked up. The oil cooler is not presently hooked up but i can use fan to move air through and out the back.
...tuft studies show....
