Hi,
I am currently working on two Panteras. One car  is a very early '72 model, the rear of the transaxle ist mounted to the middle of the rear chassis rails with a single bolt and rubber bushing, the differential and gearbox housings have matching serial numbers stamped on them. The other car is a mid '72 model with the transaxle mounted to the chassis with 2 lateral flanges and without any serial numbers on it.
My questions:
- How do i identify the transaxles, are they -1, -1.5 or -2 versions?
- Is it possible to swap the transaxles on the cars?
Any help will be greatly appreciated.
THX, Carlo
A -2 ZF will have the bellhousing attached to the main case in 7 locations ( 5 from the outside and two inside the bellhousing) A -1 will only have 4  ( with 2 additional bolts between the bellhousing and the side plates.
Also the -1 will have 2 small " windows in the bellhousing and word " DeTomaso " cast into the starter hump.  A -2 will have one larger " window" on the driver's side.
The input shaft is slightly shorter in the -1 and a different diameter ( both 10 splines)
Ron
