Originally posted by Husker:
Originally posted by DC-DD:
Cool piece but that price tag seems to say really do not want to sell just show it off.
Dominic
It is in a plexiglass display case after all.
OK but, they are the wrong carbs, the bellcrank is installed backwards, and the manifold has been modified from stock with the drilling for the nitrous.
A much more likely number for a minimum run would be 100. 13 makes no sense whatsoever.
The original manifolds are thin in critical areas such as the carb mounting flanges and the corners.
The value of that manifold would be as an historical piece and that would be for museum display.
I want a discount. Mad
Originally posted by forestg:
This one is for sale for only $700.00.
This would be the way to plumb nitrous to it also.
The ga-zillion dollar manifold is really plumbed for vacuum and a vacuum gauge at that.
Gee-ze! A gazillion bucks. Who would have figured?
If one had the two manifolds side by side you can clearly see where the Hall manifold is thicker.
