David (Mr Berman),
The only way unburned oil can get into the exhaust system is via the exhaust valve guides. Those stem seals have to be in bad order.
cowboy from hell
Well, that is something very definitive to look into! Thanks.
And Mr. Pence, let me add how much I appreciate the new formality here on th EPI board.
Best regards.
Best regards.
How about checking that one of those intake manifold gaskets didnt slide down and shes sucking oil ??? A quart every hour ... and no blue smoke ???? HMMMMMM
Or where is the PCV connected do you have one ??? My car sucked down 2 quarts of synthetic before I knew it. I put back reg 5w - 30 and not a drop in 240 miles.
Ron
Ron
Ron
Ron
David, I had a motor that was blowing oil out the breathers. We added a windage tray and breathers with baffels and that stopped the problem. It's time for another rum before the snow starts.
Richard T.
Richard T.
Hi Richard and Ron. Thanks for the help. I also had K&N filters popping out of the valve covers until I got the Hall PCV - which I think I connected properly. See pic. I have a Milodon Windage Tray.
I obviously lack the experience and just don't understand how oil can be consumed without this being visible - either as a leak somewhere or as blue smoke when it's burned. I don't know if this means anything, but adding and changing oil all the time I notice on the dipstick how quickly my clean oil turns black.
I am going to have a leak down test done and see what we find. What George says seems to makes sense.
Oil that turns black quickly normally indicates excessive blow-by past the rings. However, David's problem seems to be raw oil getting into the exhaust system, not oil that has been burned in the combustion process.
Here's my thoughts about what is happening to David's motor.
First, the only way oil can get into the exhaust system downstream of the combustion chamber is via the exhaust valve guides. The Blue Thunder heads on David's motor do not have an exhaust cross-over, so a leak there is not possible. Some mechanics do not believe exhaust valve guide seals are necessary, and they asemble the motor without them. I have a suspicion this might be the case here.
At low rpm, I believe the exhaust is blowing up the guides, and getting into the rocker arm/ valve spring area of the heads, polluting the motor's oil. Then, at higher sustained rpm, the high velocity exhaust gas flowing past the exhaust valve guides is creating a venturi effect, drawing oil down the guides and into the exhaust system.
cowboy from hell
cowboy from hell
I'll go along with both those thoughts .. not sure why anyone would eliminate valve seals ..a 2 cent part .. blow by on a brand new motor .. sorry guys .. but its time to find a new engine builder. I would not be a happy camper pulling that Work Of Art apart a second time.
Ron
Ron
In addition to what everyone else has observed, I have seen oil in the exhaust from 1) headers that scavenge too well. Yup they suck the oil through the stems with or without umbrellas. The seals just reduce the amount, not eliminate it.
2) valve cover leaks running down on the header flanges. Stupid but true.
Not to be argumentative either but I don't believe in a PCV system in a real HP car. Oil syphons out of the valve covers and into the intake manifold.
All you guys with the aluminum high port C heads listen up.
In order to keep the valve springs from failing under racing conditions, they were designed for racing, they build about two inches of oil in the valve cover to submerse the spring in oil and cool them.
In a Pantera with it's low carb location a big syphon flow into the intake manifold is created.
It is possible that a big cruise (a couple of hundred miles) will suck in most of your oil.
How do I know? You don't want to know.
With an engine that runs as hot as a Pantera, and synthetic oil, you won't get any sludge build up in the car with an open breather.
Run you breathers at least two inches out of the covers too. The oil level in the covers runs very high.
When I changed those hot rod filters for the PCV system my biggest surprise was how noticeable the difference was. I may have lost a couple HP but I sure didn't notice it. What was obvious was how much better the engine was breathing. It wound up faster and ran cooler.
Since I'm always adding oil I check the PCV hoses and connections all the time. There is never any oil in the hoses or in the breathers. There are baffles which have oil on them so I know the level get up there - but there is a piece of foam just inside and it's always dry. All that's going thru the PCV system is air. It's not picking up any oil there. There's also no leaking from the intake, heads or valve covers. What I read here sounds like a correct diagnosis and it's easy enough to check. I'm going to bet it is leaking from both ends - the rings and the valve guides. I let you know soon.
PI Motorsports shipped me my 427 with the same "hot rod" open breather filters that Deeb started with. The engine has severe blow-by, and so those little filters were immediately soaked in oil and dripping on my headers. On Deeb's advice, I also installed the Hall PCV system and have been happy with it since. I have noticed no additional oil consumption.
I wrote a post a year and a half ago about the hydraulic portion of the Cleveland oil system, everyone seemed to appreciate the info. Maybe its time to do a post on the complimentary subject, which is crankcase evacuation. Its all pretty simple once you understand the concerns. But its just as important to the proper operation of the oil system as the hydraulic portion. Hint, the valve cover is the wrong place for the PCV valve.
Can't right now however because I'm working on the fall magazine. Maybe that would be a good article for the winter magazine? what do you think?
by the way Peter, congratulations, 100 posts!
cowboy from hell
cowboy from hell
Thanks for the good advice, folks.
Well I finally got results from Tommy Hodges who did the leak down test today.
All cylinders showed a consistent 8%-9%. This at 40º F California weather in an engine that hasn’t run in weeks. Warm we believe this would be down to around 3%.
A stethoscope confirmed air leaking into both the oil pan and valve covers.
Oh yeah, the plugs (almost two seasons old) were oily, but in decent shape.
So the expert opinion is that the angle of the 408 stroker, the 6" con rods, the chrome moly rings and the still limited mileage (less than 5,000 miles) contribute to a fact of life I may have to live with. And I'll keep on adding oil as I go.
The motor runs well, is extremely tame and streetable, yet kicks some serious butt. I have never lost a street race yet (Porsches, Vipers, Ferraris, NSXs, Vettes and a few carefully chosen rice rockets).
We've come to the conclusion that the guys who did a god job building a nice loose hot rod motor to give me this kind of performance (522hp / 510 ft lbs of torque) didn’t really care about adding oil after every 1/4 mile run. So be it. I'll just continue to carry oil with me.
Now all I have to do is figure out how to avoid the yellowing across the rear face above the bumper. Here are some options. I am open to comments and suggestions.
1 - use synthetic oil that yellows less and is easier to clean
2 - extend the rear exhaust pipes slightly
3 - modify the exit angle of the pipes
4 - fab an undertray to boost the airflow and oil away from the car
5 - find the stuff they use to protect new cars in transport; cut a bunch to fit the rear face; then stick it on before a long trip and rip it off when I get there
6 - drive shorter distances
7 - bring my wife and a spray bottle of degreaser whenever I travel
My engine build details and parts list along with dyno info is attached for any experts who wish to investigate further.
Files (1)
Try Eastwood. They have some clear, removable plastic from 3M.
quote:find the stuff they use to protect new cars in transport; cut a bunch to fit the rear face; then stick it on before a long trip and rip it off when I get there
Clear products that spray on and then wash off.
Griot's Garage has one and
http://www.duplicolor.com/products/shield.html
manyponies (Guest)
A 4" stroke in a Cleveland block is not extreme. The oil ring having a spacer rail support for the oil ring should give no ill results. The 347 stroker brought this to attention because of its oil ring placement and smoking issues. We have over 100 347 strokers being used on the highways and no reports of smoking problems. All of these engine have the oil ring intercepted by the wrist pin. The oil ring in an engine is SUPPOSED to oil the cylinders. The second ring is actually the oil scraper. Most think the second ring is a compression ring. This could not be any more untrue. The shape of the secong ring will NOT allow it to hold pressure from the top of the piston. I attribute most of these smoking problems to improperly honed blocks. Oil control is achieved by a proper finish, straight cylinders, and a good relationship between the two. When we dynoed Chris Lewis's engine there was no air coming from the valve cover breathers which we ran uncovered on the dyno so he could visually see what NO blowby looks like.
On a different note pan vacuum is hard to pull when there is any blowby past the rings, even more so on a forced induction engine. We have a 9.2 deck engine with the oil ring intersecting the wrist pin that runs 40 psi of boost making 2700+ hp and pulls 15" of pan vac.
The proper stones to hone this way are expensive, they wear fast, and cannot be used until they are worn out. A hone job is more than making things look pretty.
Mark,
correct me if I misunderstand. Your position is that the wrist pin intersecting the oil ring, especially as little as it does in a 351C 4.00" stroker with 6.00" rod, is not the source of oil burning in these motors, its the cylinder prep that results in the oil consumption?
If so, is it then possible to build a 4.00" stroker, 6.00" rod, 9.2" deck motor, that didn't consume any more than a quart of oil every 5000 miles?
That would be very good news. I have been told by other engine builders that the wrist pin intersecting the oil ring was the source of oil burning, and this is what I've passed along to the members of this forum. I never understood why it would cause oil burning, it didn't make sense to me, but I accepted it as a empirically determined fact.
To get the rings to seal so there is no blow by, I'm impressed. Now I understand why your runt is as powerful as it is. I was taught as a young man that ring seal is everything in terms of the potential of a motor.
George
George
detom (Guest)
Gosh George, a 4" stroke and 4" bore. That would make a square engine. Isn't there something about torque and horsepower numbers getting turned around on over square vs undersquare designs?? Isn't that why desiel engines make more torque than horsepower?? Am I totaly lost dazed and confuzed???
manyponies (Guest)
George, All of your deductions are 100% correct. We build many 4.00 stroke Clevelands with no issues on oil consumption. Ring seal is the key to making power. Next we can work on cylinder loading theories and how to make it easier on thin cylindered engines. If there are any topics like this that maybe I can shed some light on , send me some suggestions as I'm thinking of adding a tech page to our website for good discussion topics. I have no problem answering questions like this.
To steal a quote "An educated consumer is our best customer".
