iam installing halls new compressor and the belt is so tight it wants to twist. should i open the holes is there mounting plate to move it closer to the crank. its a pain i cant get out
quote:driving that's outboard of the A/C Compressor???
quote:Originally posted by Rocky:
Devil -
How do you adjust the water pump tension?
Don't forget your hose clamps!
Looks good!
Here is mine..
SAAC Industries "Amazing" Underdrive Water Pump Pulley
IPSCO Water Pump Pulley Tensioner
W-Wadeco Fabricated Bracket
Sanden Rotary A/C Compressor
Idler Pulley
Stock 3-Wire Alternator Mounted Outboard
I can get you belt lengths if interested - it took me LOTS of trips to the Auto parts store to find the right ones.
quote:Belt manufacturers will tell you that putting a reverse bend in the belt will lead to shortened belt life.
