Aloha All,
Just finished installing the Baer SS4 upgrade up front, and Wilwood rear rotors (with stock rear calipers and EBC Yellow Stuff pads on all four corners), and we're running into a couple interesting issues. First, the yellow brake pad warning lamp burns all the time, even though the chassis wires have been bundled/tucked away and the connectors liquid-rubber coated to prevent shorting. Second, with medium brake pedal pressure at 30 MPH, the right-front locks, and is nearly impossible to modulate. Apply moderate pedal pressure to stop the car, and you end up with a lot of tire smoke and a deep flat spot.
I haven't seasoned the rotors or bedded the pads yet, as I want to address these issues first. Any ideas?
Mahalo -- Scott
