Typically, their life is much longer, but catayltic-equipped GT5-S cars may put more heat than normal into the area around the aluminum engine mounts. The rubber spacers tend to squeeze wedge-shaped after decades of use on pre-L and L cars, which then forces the motor mount-to-block bolts to bend & break. So on those cars, every decade or so its advisable to unloosen things and rotate the rubber 180 degrees to distribute the load. One thing we know DOESN'T work though is polyurethane replacements for stock rubber. Even in a pre-L or L car, the urethane will liquify from header heat, causing much trouble even getting the motor mounts out of the area, to be chiseled apart! On your car, I'd check the bolts holding the upper mounts to the block, as it sounds like the engine is pretty unsupported now. There's also a long bolt holding the two halves of each motormount together; its often put in with the nut upward, which is not correct. There's a drilling in the end of the bolts for a cotter pin, so if things loosen up, the nut won't unscrew & let the bolt drop onthe road. Many Panteras have the bolts in backward.
