Got my block back from the shop and noticed that they did not put the end freeze plug in. I assume that I install the cam, put the retainer on then pound in the freeze plug until it just touches the cam so that there is zero play. This is a roller cam so I assume that there really should not be much movement. How do you know how tight the cam should be? Should I put any sealer on the freeze plug?
Thanks
