Another trick to help scrub the inside clean, I learned this working in a bar cleaning the coffe pots. Put a couple spoonfulls of salt in the reservoir, add ice (crushed works best but cubes will work). Swirl the ice/salt around the inside of the container. The ice acts as a carrier for the salt which acts as an abraisive inside the bottle. Made those coffe pots shine and I have used it on other containers with heavy deposits. Good Luck.
