I replaced my clutch master cylinder with the aftermarket pim cnc version, and the long throw slave unit two years ago. I have bleed the system several times. The problem is that the car starts to walk or move after the clutch is pedal is held at a stop light for awhile. At first it doesn't do it at all, but then gets worse. I just rebuilt the transaxle, it shifts fine, and the pedal is pretty firm. I am thinking that the clutch master cylinder is bleeding through, there is no fluid loss. Any ideas?
