The slave cylinder is retained in the bracket with large snap-rings at each end of the bracket. There may be paint obscuring the snap rings. Remove one snap ring & the cylinder will fall out in your hands. Aftermarket std & long-throw cylinders fit in the stock bracket the same way, and use stock hydraulic fittings.
