As part of some long over due maintenance, shortly I will be purging >stale<<BR>DeTomaso Registry accounts.
Any account that has not been accessed in 8 years or more will be affected.
This should be a small number of accounts.
If you have not used your account in a long time I suggest you “check in”.
Remember that your e-mail address is your account ID (Login).
Note that both your account and password are Case sensitive!
(case, CASE, CaSe and Case are all different)
If you have forgotten your password, then at the login page:
http://www.detomasoregistry.org/login.asp
Enter your e-mail address in the “Login” box, and then click in the box “Send My Password”
and click the “Login” button. Your credentials will be sent to that e-mail address immediately.
(If you do not receive an e-mail with your credentials check your spam folder. Automatic e-mails
like this are often treated as spam by YOUR service provider, which is an issue I can not resolve for you.)
When you successfully login, you are at the “Member Main” page.
A) In the left column click on “Member Account”.
This currently provides limited info, so click on the link “Click Here”. On the next page
click “Submit Query” and a list of cars connected to your account will be displayed.
OR/AND
B) Click on the De Tomaso Registry Logo (to the left of the changing image) which takes you to the Registry Main page, and click on the “Update an Existing Entry” link. On this page enter the short VIN of a car connected to your account, and then click “Search” to locate the specific entry. Change some field (I suggest tire description), scroll to the bottom and click “Submit” to finish.
You are done updating your entry and also refreshing your “last logged in” date.
This would be a GREAT time to send even just a couple of fresh photos of your car(s)! Send photos as jpg attachments, with VIN in the subject line to Editor1@provamo.com (for automated processing).
If you have need of assistance, or have changed your e-mail address,
contact me via the “CONTACT” button found at the bottom of every page, or e-mail me via
admin@DeTomasoRegistry.org.
Best Regards, and Happy New Year from the De Tomaso Registry!
Chuck
(The Registry Guy)
www.ProvaMo.com
