Hey guys,
I am wondering if anyone else has suffered something similar to this....
I am now on my fourth altenator in ~ 3 years. My car seems to be eating them. It also killed a coil last year. I get a very brief warning - my amp gauge goes below zero and I get home quick. The most recent time, I recharged the battery, and when I restarted the car and ran it for about 5-10 minutes everything was working fine. Could an intermittent issue with something going to ground cause this?
-Sean
Sean,
Does your Pantera possibly still utilize the oem voltage regulator? Electro/mechanical voltage regulators sticking open or closed was a common electrical system failure, back in the days of electro/mechanical voltage regulators. They have solid state replacements that drop right in without any changes to the cars wiring required. I am in agreement with Larry & Derek that your problems sounds like classic voltage reg trouble.
Of course, there are modern high output alternators available with built in voltage regulators, they will require a bit of simple rewiring.
your friend on the DTBB
Sean,
Go with George's suggestion...the one wire alternator with the built in regulator. I am not saying they won't fail but they don't seem to. Also, you get to eliminate some wires from your system. That is never bad!
Most of the vendors can sell you a good one.
Cheers!
Mitch
Johnny,
There are alternators with internal voltage regulators having truly only 1 heavy wire connection, and there are those that have several wires. Often both types are referred to as one wire alternators. The only advantage of "true" one wire alternators is they reduce the amount of wiring in the engine compartment, a concern for owners of show cars. In a Pantera, the wiring up front really isn't visible to an observer peering into the engine bay from the rear of the car, and therefore there is little advantage for a one wire alternator, even in a Pantera show car.
There are several disadvantages to the one wire alternator. I do not recommend a one wire alternator, and suggest the Ford 3 wire alternator instead (voltage regulator is still internal to the alternator).
I fished around the internet and found this essay on the subject:
http://www.madelectrical.com/electricaltech/onewire-threewire.shtml
Your friend on the DTBB
Johnny. Agree with George regarding the 1-wire vs. 3-wire alternator issue. I ended up with a new Tuff Stuff 7078RC 100 amp, 3-wire alternator via eBay for $110 (shipping included). I installed a new electronic voltage regulator at the same time. I imagine The alternators are also available through most on-line performance shops. The RC version is chrome. So, it looks really nice when you've got the firewall cover off. Smiler
You can check it out here: http://www.tuffstuffperformance.com/products/part.asp?partid=139
Enjoy,
Ron
  • 7078Rbg
Thanks for the feedback guys. I'm in China right now and don't get to check in too often.
The last three have all been 100 amp alt's with internal regulators. They are the three wire type and my idiot light goes on when I'm past the point of no return. I'm working with Pat Mical on this and he is pretty sure we just keep getting bad altenators but it is starting to seem too unlikely to me. Maybe I should still use an external regulator?
My voltage regulator fried a month ago.I have my dash apart now because I traced a burn't wire to my gen. warning light.The wire jacket was melted at the regulator and gen.warning light.Looked good in between.My advice to anyone with the OEM regulator is replace it quick.
OK....now I am really confused. Everything seems to have healed itself. After recharging the battery, it has been fine now for three excursions (close to home since I don't trust it yet!). I am really thinking there is something shorting out in the wiring harness somewhere in the car, but it only happens intermittently. The wires to the idiot light and to the amp gauge have all been replaced. There must be a gremlin somewhere else in the soup.
...Buy the 100 amp Alternator from 'Hall Pantera'!! Not only does it have a Internal regulator, It also has a Intenal Cooling Fan. Yes, the 'GEN' light must be disconnected and the two wires going to that light, joined together; in order for 'it' to charge properly. I have had mine installed for over three years; from then on, I have never had to so much as think about it again...
