Are you looking at a unit for a Cleveland block or for a Windsor block? Only asking because I have a new in box unit for a Windsor that is for sale. I ended up using a Holley dual sync distributor and don’t need the Price unit. BTW, Bill Price is extremely knowledgeable about Ford engines and makes quality parts. He did some custom machine work on my Clevor EFI intake manifold. Work he did is top notch.
PME's cam synchronizers use OEM Ford signal generators. The 2 wire is a Hall Effect unit and the 3 wire is a VR unit. You would use the one that's compatible with your EFI ECU.
The only difference between a 351C and 351W distributor is the gear.
Julian, the old MSD cam synchronizer used a proprietary signal generator that output an "unusual" square wave. It was designed to be used with MSD's CPC ignition system. Some ECU's (eg. Electromotive) worked great with it whereas others did not (eg. Accel). The new MSD/Holley cam synchronizer outputs a normal Hall Effect signal but I don't believe they're available for sale yet.
  • PME_Cam_Synchronizer_with_composite_gear
I'm looking to run an ignition rather than a fuel system,
looking at the MSD description & the instruction sheet i think i need a crank position sensor rather than cam synchronizer?
IIRC the AEM Engine Position Module (EPM) has 4 wires and functions as both a cam synch and crank position sensor but it seems they've dropped the 351W version out of production
so I'm following links and find this
http://www.network54.com/Forum...+Manifold+Conversion
I've been thinking to myself all i need is a mini-distributor to run a primary voltage signal and i scroll down to see the capless dizzy. that might actually fit under my blower drive snout?
what ignition box will a magnetic pick-up (Duraspark) or optical sensor (Unilite) dizzy bottom trigger and supply signal to individual Coil On Plug coils?
can a stock Ford OBD II ECM be triggered by the dizzy bottom?
