Enviro-safe is selling R600a. More commonly known as iso-butane. Butane, you know, the stuff they put in cigar lighters. Its a hydrocarbon, a fuel, its flammable.
True, it makes a great refrigerant, but the SAE thought it best to avoid using flammable refrigerants, because the refrigeration system cycles through the engine compartment AND the passenger compartment. A leak in either area could be disastrous.
your friend on the DTBB
Not to mention, in a front end, or in the case of the Pantera a rear end collsion, the first thing to get hit and start leaking is the a/c cond. Butane is not something you want leaking out especially during a accident. Unfortantly I'm seeing more and more a/c systems charged with it. In fact my recycler machine has a warning sensor to protect against contamination of butane. I'd pass on it.
Nothing works as well as R12. Period.
Last year I spent about $800 and had a bad hose replaced, full system evacuated and recharged with 3 1/2 pounds of R12. On a cool day, I see a steady 40 degrees coming out of the dash vents. The drive home from Vegas this year was quite pleasant.
I recently obtained my EPA section 609 R12 license online for the total cost of $15.
This allowed me to buy five 14 ounce cans of NOS R12 off eBay for $81.06, delivered to my door.
I bought a used set of R12 gauges off eBay for about $40. I need to buy a can tapper and I can keep my system charged and ready for at least a few years at no added cost.
Used,gathering dust in some corner of a garage R12 recovery machines often sell on eBay for $100-$200. Most are pick-up only due to their weight. When I find one of them close enough to home, it too will be in my garage.
Mixed refrigerant systems are persona-non-gratis at any AC shop that is aware of the mix. Service thus becomes a PITA.
134a will be phased out just as R12 was.
I'm sticking with pure, reliable, efficient and still easily available R12.
YMMV
