2020 navigator, one per vehicle.
This muffler has a two in and two out, this a resonator, I'm facing the system now so I'll take some soundings of the current system which is a double glass pack system so I have the advantage of two in for the muffler.
What you've done, so far, looks great. That's a great find on the Navigator mufflers too. As you know, the big stumbling block in creating an exhaust system for the Pantera is finding an appropriate muffler cannister. Since they call it a "resonator", I assume it's a straight through design without baffles. Do you know the ID of the inlets & outlets?
If this works, you should make about 50 sets because they will sell fast.
@davidnunn posted:What you've done, so far, looks great. That's a great find on the Navigator mufflers too. As you know, the big stumbling block in creating an exhaust system for the Pantera is finding an appropriate muffler cannister. Since they call it a "resonator", I assume it's a straight through design without baffles. Do you know the ID of the inlets & outlets?
It would be interesting to open one up to see what the insides look like?
Resonators are straight thru, I've added DB killers into each inlet and this has reduced the sound level from what it was with the glass packs. I'll add some pic's.
VERY nice ‼️
I have a feeling they are going to be on the loud side of the spectrum. 😉
I’m curious about the dreaded 2,000 rpm resonance too!
I'll let everyone know the 2000 rpm performances.
How did this muffler project work out. It looked very promising.
how did they work out? my Pantera is deafening loud. headers with 4 glass packs that i’m sure burnt out decades ago
How did the navigator mufflers work (fit/sound)?
