is a few shifts away from a trip to the machine shop to resurface
It seems hard to believe that you wear 1 mm off the clutch with every shift.....
It may be thin, or it may not be.
I personally think that if he has the clutch apart (and is measuring 1-2 mm directly) he may as well replace things "while you are in there". And a clutch is only $400-500, right?
Sometimes I think we get a bit hysterical about "what could happen" on this board... Maybe I'll start a new thread on that!
Hello Rocky; For myself an afternoon of track time at Laguna Seca is worth 1mm of clutch wear!!!
I personally value my time.
If "I" had a ZF removed from the engine to be able to measure 1-2mm LEFT between the clutch surface & the rivets, there would be NO reinstalling that clutch!!!
The lining of a clutch disc is like brake pads. It is designed to wear.
Everything is involved in the rate but the lining itself is not the issue with a Centerforce.
It is the silly things like the fingers on the pressure plate that wear disproportionately in comparison to others.
The problem with Centerforce is that it has become a two bit company because the original concept was not adhered too.
It has been sold several times and components are manufactured "off shore" and are supervised by "sales oriented" managers rather than actually pay an engineer who understands and more importantly CARES about the integrity of the product.
Use your Centerforce and when it is due for a new unit be advised to go elsewhere.
The Chinese and Vietnamese who make this thing now just are happy to have a job and just do what they are told to do.
That has absolutely no basis upon the quality of their product.
Rather than have the diaphragm fingers blackened from heat treating like they are supposed to be, they just spray them with black paint.
Not quite the same thing and the product is now just a mere shadow of what it was.
I would also note it's hard to get the P/N for just the clutch disk from Centerforce.
After a whole bunch of detective work, I found it, but they wouldn't sell it to me direct. I finally had to buy through an authorized Centerforce dealer. It was as if they wanted me to buy the whole assembly for the Pantera. Maybe not too surprising.
