When I finally did manage to remove my fuel tank drain plug I inserted a powerful magnet inside the hollowed out plug.
Just like an oil drain plug.
I have removed this plug a couple of times since & it has picked up a reasonable amount of rusty metallic particles.
Last time I removed it there was very little, real clean.
Easy way of removing some of the built up debris & helps to keep scale out of the fuel filter.
Regards,
Tony.
Done. It had been out a year or so ago but I just didn't remember what the thread was on the plug.
Magnetic plug is a good idea.
Unfortunately the fuel gauge sender in now morto bene. It's only been in there for 40 years. They just don't makes thing like they used to? Who is they anyway?
Looks like the fuel pick up committed sympathetic suicide with the sender? I don't know...these Italians! Big Grin
Are you having trouble removing the plug Doug? Don't see that was part of your original post, but folks are answering the question you didn't ask anyway. So I'll chime in too...
To remove a gas tank plug frozen/rusted in place:
1. Soak plug threads thoroughly with lubricant. 50/50 mix of acetone and ATF is best, but you may be able to get by with WD-40. "Thoroughly" means overnight at minimum; better, soak for 2 nights, and keep reapplying lubricant solution so it may wick into the threads.
2. Use an impact wrench set on the lowest torque setting.
The hammering of the torque wrench will remove the plug in short order without damaging the tank's delicate sheet metal surrounding the plug bung.
