Hello all, I have a engine whit 3VCHI heads and a Edelbrock performer 351 4v intake. Now there is a big cap , 11 mm, between the intake and block . How can I fill this cap on the good way?
I read somewhere that the CHI-3V heads only work with the matching CHI intake manifold. That is why the end gap is so tall using your Edelbrock manifold. The 3V is unique.
Originally posted by T.Solo: I read somewhere that the CHI-3V heads only work with the matching CHI intake manifold. That is why the end gap is so tall using your Edelbrock manifold. The 3V is unique.
Steve
Thanks Steve, maybe you are right. Go do some investigation this way. Simon
Steve
Yup, absolutely correct.
If you search long enough on the CHI website, you will find this in their FAQ section.
