Originally posted by ROVERLTD:
They could be close. Or retapped by a previous owner. What are you trying to accomplish? Trying to suck from the bottom of the tank? IF so I know of a Parker Valve fitting that is a 90 degree that goes from the 22mm to a AN fitting. Could provide the Parker Part number if interested.
Thats it, a friend is going to try a bigger fuel line! Parker valve fitting?, that sounds like it may do the trick! The part number would be great! Also where would we find the part? Thanks
