So earlier I had a problem where my lamps would not go down. I found that by jumping the limit switch, I was able to make the lamps go down, so Ok, I probably have a bad limit switch. But now they won't go up either. Is one bad switch capable of causing this or do I have two bad limit switches? When I jumped the down limit switch, the lamps went down much faster than usual, almost like a modern car, which I thought was nice.
Any ideas?
