I am looking for a set of headlight buckets for a car I will be working on soon.I'll have to get back to you on the year (I know that the later cars had a different bucket)
Ron, I went through some headlamp bucket woes, The early ones had bolts through holes, and the later ones had mounting studs on the bucket. The trick is to adjust the opening in the fender to fit the buckets. I used fiberglass from undeneth and trimmed it so you could not see light around the opening.
