When I move the indicator arm to the right position the headlights cut out momentarily then comes back - then cuts out etc. If I put pressure on the switch arm the lights will stay on - until I ease the pressure of.
Bill fixed mine about a year ago. He is a fine fellow to deal with and his work is worth more than he charges. He gave me the hot tip for removing the turn signal switch assy. so the stearing column wont end up in your lap during removal.
