My problem is I need the whole assembly. I have a 71 with the old style blower. I've already had it out once, and it wasn't fun, and replaced the brushes. Didn't last long before it went out again. I would like to find a better than stock aftermarket replacement so that when I take the dash out again I can install the new and go back together.
Thanks in advance.
I did this like 7 years ago. I can't find the receipt, and I dont want to pull it apart but I can if there's enough interested.
Its like a BM 0393 from polarbear inc (or something around there). I had to modify the clamp to accept the larger motor housing but it works. Much more powerful and 3 speeds (so you choose they two you want when you wire it in).
Don't order that P/N blindly without doing your own research, like I said I can't remember exactly and no receipt.
Dave
