I received my new camshaft with a LSA of 115° and a timing recommendation with Intake Center Line at 113°, I had another recommendation with the ICL at 110°.
In your opinion, what difference will a timing at 110° rather than 113 have on the behavior of the engine?
Not a lot of difference initially in feel. The 110 feels more peppy then the 113 even with similar timing and valve lift.
The 113° will have more vacuum at idle then the 110° will.
So I think of the difference as one is better for an automatic transmissioned car. The 113° and the 110 is more ACCEPTABLE for a manual transmissioned car.
For me, I would not want to drive a 110 for an everyday car. It is a toy that I take out and play with when I want to play boy racer.
The 113 is less abrupt and smoother enough to live with ALMOST every day. It feels more stockish.
Others will describe it differently, I'm sure.
If you are talking about dyno results, I saw a difference with the the engine power caused by the differences in cam timing. For example, the "Weber cam" v. the Compcams solid. There is around an 80hp difference between them at maximum power. The "Weber cam" is a 113. The Compcam a 110.
As intended, the "Weber cam" didn't have the same level of fuel reversion that the Compcams has but it was down just about 80hp as a result of the overlap timing differences.
The "Weber cam" is also a hydraulic roller lifter and the Compcams a solid flat lifter so that does have something to do with the power output and the power curves.
I've always found it ironic and somewhat contradictory, that what the dyno sometimes clearly shows, the difference in the "power under the curve" on the graph, doesn't necessarily translate to me in the "feel in the seat of the pants thing"?
I suppose that may be in the way that I like to drive the car? I can't drive a dyno.
Thinking back, my "Boss 351" had a 113° Shelby solid lifter cam and would break the traction loose at around 4200 rpm FROM AN EASY NORMAL ACCELERATION. That matched up with the maximum torque the dyno showed. 380ish at around 4,500. So to drive that one I had to feather the throttle to not break traction.
The solid lifter 110° is easier for ME to drive. It seems linear, not as peaky and if need be I just put my foot in it all the way. I just look to keep it under the top rpm limit.
I don't know if the same will translate to these new cam profiles?
When confused, I always look back to what Ford did with these engines to make them civil enough to be everyday drivers as a guide. That tells me a lot.
Many engines are a wolf in sheeps clothes but when you unleash the wolf, it's still a wolf and it has it's everyday use drawbacks.
Ford is correct in that MOST will be happiest with the stock CJ cam.
