Posted July 26, 2007 03:27 PM
I need a/c condensor/fan/assembly/dryer,
See this link for the condensor/shroud/fan replacement I just did on 2511.
http://tinyurl.com/29mu8bFeel free to P.M. me with questons on the install if you decide to go this route.
While you are at it on the A/C system, there are a LOT of areas that you can upgrade and/or need to replace, especially if you move on to R134a;
R12 or 134 conversion is up for debate, but you certainly want to dump the York compressor (you'll need a readily available conversion mounting plate) in favor of a newer Sanden 508 - NOT the new China street rod knockoff or a rebuilt unit - new barrier hoses are a MUST for 134, Wilkinson has a new evaporator that he says is THE ticket to good cooling, and a new drier with a switch port for trinary switch. A trinary switch incorporates a high/low pressure system to interrupt your compressor clutch power, and thus protect it from damage.
You've come to the right place for help. Keep the questions coming, the more specific the better.
