I have a 74 and I'm having a little problem with my Ignition Key. The switch itself is fine however my Key is getting worn and will only work in one direction (two sided key). I have tryed having new keys made but no luck. The locksmith would like me to bring him the internal guts on the lock. On some cars there is a .070 hole in the face of the cylinder that you can install a paper clip into to remove the tumbler, but not on this one.Has anyone ever pulled out there tumbler assembly and how was it done? Thank's for you're time
