Has anyone actually checked the weight of their car? I put mine one the weight today, and with an 80kg driver inside, it weighs 1740kg (3836lbs). This is quite a lot less than the 1940kg stated in the cars papers.
Would be interesting to see if a stock Deauville actually does weigh 1940kg, or if it's lighter than stated.
1000 kg / 740 kg front / rear axle weight.
20241019_100202
Late night pre-drive inspection yesterday.
20241018_180049
Images (2)
  • 20241019_100202
  • 20241018_180049
It must have been the bubble flare then. Altough I seem to remember that some connections on the distribution block needed bubble flares as well. But it has been a while since I worked on mine.
Some of the electrical solutions are curious indeed. Either wel thought out or not at all.
Is there any fiberglass in the Jehle conversion or is it all steel? I never weighed mine but it would be interesting to see what the weight would be. Must put it on the scales sometime, we have a set to set up the suspensions and corner weigh the racecars that we work on.
The 4 speed conversion must be a real bonus!
The handbrake pads are a girling system I believe. Also used on the Aston V8s, Rolls Royce Silver Shadows and Jensen Interceptors. They look really odd because of the way they seem to be worn away on one end and not on the other end.
Powerflex poly bushes do have most suspension bushes and the rollbar bushes, though not fot the drop links.
