Originally posted by Rapier:
...George, am I correct?...
The '70 - '71 M code motor was called a 351C 4V.
The late '71 - '72 Q code motor was called a 351 Cobra Jet
The '73 - '74 Q code motor was called a 351C 4V, even though in essence it was a Cobra Jet spec motor with tweeks for exhaust emissions.
The '73 - '74 motor was installed in all the US Panteras (the L models). Technically the motor in Dennis' L should have the small valves.
There are 3 explanations:
(1) Ford mixed and matched motor parts (installed 4V valves in the '73 casting, or installed '72 heads on a '73/'74 short block)
(2) A previous owner has swapped heads
(3) A previous machine shop installed larger valves during the course of a valve job (intentionally for performance, or unintentionally, not knowing the '73 heads actually required the smaller valves)
cowboy from hell
