Originally posted by jeff6559:
I had to lay mine forward about an inch and a half to get the flexalite fan assembly to fit behind the radiator. I also put a small spacer between the fan housing and the radiator as suggested by Jack DeRyke. I also have the upper shrouds covering the openings in front and back of the radiator. No overheating problems.
Unless you have the hood cutouts, laying it forward any further may be counterproductive as all you've done is reduce the frontal area for the air to blow through.
Jeff
6559
Yeah, what he said. I did exactly the same thing on my '72, with I imagine the same flex-a-lite fans. It would slowly overheat in traffic before, and it literally never overheated once after the installation.
