Sometimes they can sometimes not. It depends on the problem, especially with the ignition switch which has 2 trouble areas. One is the electrical portion the other is the mechanical side for the key.
some times the starter only makes a klicking noise. If I go into the front trunk and jump awire across to where the old emergence start switch was the car cranks right over. Then I go back inside the car and turn key and the car starts right up. I think the problem must be in the switch. Was this switch in the front trunk also some tipe of relay?
joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
Sounds like you have a problem in the starter interlock/override circuit. The override switch is forward in the front trunk. Most people I know have ripped all that out.
I had a 64 vette that would not start, sometimes, when hot, I put on starter heat shields. I had a jumper wire permenatly attached to the starter solonoid so I could jump it to the batt. One day after pulling out hair, I noticed that the 30 year old wire feeding from the switch was kinda stiff, and brittle. I replaced it and it solved MY proplem. Word has it that wires build up resistance over the years, and a heavy load on the small wire somehow align/ disalign molecules that cause current flow resistance. Only when hot .. sometimes. Make sure you have a good wire and connections. Bill 1362
