...The Curvature Alignment Revealed. How did I get the Curvature this Accurate?? I placed Both 'Beams', Clamped together, Between Two '4 x 4's', and Stepped on them Jumping 5-6 Times, with My weight at 262 Lbs. Biased towards the Front End. This took a Lot of effort, the Aluminum, although SOFT, was hard to bend. Just what I needed to support 14.7 Pounds of Aluminum, at 160 MPH! When both pieces Must be Curved Exactly to each Other. they must be bent Simultaneously, doing them separately, they would be Impossible to Match!
Next pics, Working on the forward mounting, Hidden. Beams have been shortened to Not show in the Rear...Only the Last Louver will ever be seen in the Rearview. Rubber pads may be used in conjunction with the (2) Magnet, Yoke and Pin, to adjust the final Height of the Twin Beams.
Photos: The First slat to the Mounting, is Fitted. 2nd Slat is checked for fit and Not yet set for Angle.
In the Next Posting of Photos, I will show how All Louvers will be Aligned with 'Absolute Accuracy' !!
Thought you may want to see the Dish Marlin cooked Saturday Night.
'Butcher Shop Pork Chops' 1 Inch thick. Smothered in a 'Caramelized Onion' Cream, Sauce. 3 Chops cut into 6 'Medallions', Sear Very Well on HIGH, Lower to Med-Hi 5 mins per side (NO Pink in the Center), 32 Oz, equal beef/chicken stock. 3 Garlic Cloves, 3 Onions, 4 Heaping Tbs The Best PORK APORK BPORK CPORK DFlour on Onions when Caramelized, 1/3 Cup Whole Cream. Top with Rosemary and Tyme. Cooking time 45 Mins. Season Pepper and Salt.
Marlin can achieve many things beside Building a Pantera and 351C Engines. Loves to cook, as well as Play the Violin, Scottish-Irish Fiddle.
Wait until you see What comes Next!!
Images (4)
  • PORK A
  • PORK B
  • PORK C
  • PORK D
Marlin,
Can you show a rear view and also what it looks like from inside the car? Thanks!
...New photos as requested, Rearview and from Inside the Vehicle. (In More than One Posting)osotoroqonin mojoh
With temporary spacers installed, to photo 'close' angles. Permanent parts to arrive soon.
Rearview from inside Vehicle also through the Rearview Mirror. The Long 'Tube' in image is the Electric Antennae moved out of the way, during work.
Pics, Viewing from Rear of the Pantera, Looking Forward.
The Air Cleaner Box can be seen centered, from inside. Mirror View Sites straight through the Center of the Window, between the Twin Support Beams.
Plenty of Light coming in, seeing Images in Not a Problem!
Questions Welcome,
Thank You
Images (8)
  • os
  • ot
  • or
  • oq
  • on
  • in m
  • oj
  • oh
hi Marlin, those really did take shape after screwing the down, they look great!
So I have a done a little more serious mock up on my louver design, spacing is equal all around, bottom slat a little short, didn't want to cut another piece of wood, so want do you guys think, should I go ahead and order the carbon fiber or not?   Let me know what you think,won't hurt my feelings!20250102_17252020250102_17250820250102_17245920250102_17253420250102_172618
Images (5)
  • 20250102_172520
  • 20250102_172508
  • 20250102_172459
  • 20250102_172534
  • 20250102_172618
...How about some Great Feelings! In My View, Your Measuring and Craftsmanship is a Lesson in Perfection! I like Mostly the Direct Rearview showing the 3 Louvers Perfectly Horizontal, Very Accurately Spaced and Angled. You NAILED It!!
I think You Out-Did the Lamborghini! Congratulations on Designing an Outstanding 'Triple Louver'! I like to say..."The ONLY One of it's Kind in the Entire Universe!!" Your Design, There are NO Others Exactly Like It!
I think You're ready to Obtain that Carbon Fiber!! Do You have an Design of how to Secure it to the Deck? If Not, Consult an Expert.
Remember! These Panteras can 'Easily' Break 140+ MPH!
Again, Congratulations, Beautiful!! Your Work Well-Done!
Love That BLUE!
Thank You for Coming back and Posting the Photos!! It's a real Pleasure to see Your Pantera! Eye Candy!
I like both designs very much and the ingenuity. Lane maybe your spacing is a little wide for my preference, but then again it looks great from the back. I think that plane line is similar to the Delorean but wider spacing. Although I absolutely hate bringing up Delorean because I have had my car referred to as one a couple times by people that know no better (or can't read DeTomaso) the DMC louvers concept is not a bad one all one peice that sits inside the sugar scoop. Also it appears to open with a similar strut as our decklid. I believe the DMC louvers were originally fiberglass, but I could be wrong. Screenshot_20250103_110336_Samsung InternetScreenshot_20250103_110256_Samsung InternetScreenshot_20250103_110512_Samsung Internet
Images (3)
  • Screenshot_20250103_110336_Samsung Internet
  • Screenshot_20250103_110256_Samsung Internet
  • Screenshot_20250103_110512_Samsung Internet
mdmambmcmemf...Next Up, A Counter-Sink Depth Gage for 82 Degree Flush-Head Allen SS Machine Screws In 0.090" Aluminum Sheet.
Photo, Proof of Flush. Absolute! Light will Not Show under a Steel Straight-Edge.
(2) Magnetic Mounts for the 'Twin Beams', with Clevis and Quick Disconnects. To Adjust the Height and Hold the Tail Secure. Stainless.
Images (6)
  • ma
  • mb
  • mc
  • me
  • mf
  • md
...Countersunk washers to clear Flat-Head Screw 'Cone' Taper. Cone is .200" Deep. 0.090" is taken up by the Sheet Aluminum. Can't Countersink the 'Beam', that would eliminate much needed threads. So I counter-sink the 0.121" Thick 1/4" Washer, 0.110" Deep, The Just clear...with a couple of 1000th's more, for 'Crush' on the Louver.
Look Close at the Height/Spacer Assembly. With the screw thread into the Beam a Minimum of 0.240" IN, it gives a Height of 0.750", measured from the Beam to the TOP of the Louver, Maximum. If I need more Height, I change the 1" Length Screws for 1-1/4". See Countersunk washers, and (2) Flange Screws, Jam Nut set-up. Easily Adjust the Height to '0' on the Inclinometer At X and Y, and Lock it In!! Job Done!!zazbzd
Images (3)
  • za
  • zb
  • zd
...The Two 'Front' Screws, will just be the 5/8" Flat-Head Screws and One, Countersunk Washer. Also acts as a 'Load Spreader' and relieves the 'Taper'. I can also, Countersink the Top Flange Nut and Eliminate the Washer all together. That would 'Expose' More Threads for adjustments. And a 'Cleaner' Assembly.
...spending 2 days rejuvenating a Large Coy Pond and 2 Waterfalls...in my backyard. Had it for 20+ years, was Well Overgrown. Working on Night 'Glow' Lighting and New Pumps to run off the Solar array I designed and built 4+ Years ago.
Got in Tonight and was able to work on the Aluminum Plate that Finaly, Arrived.
That's a 0.187" (3/16") Aluminum Plate 4" Wide and 36" Long to be Trimmed to Lock in and under the Inner Ceiling with a 'Bank-Vault' Cloiser.
You'll Notice in the first pic, the screw holes are 'Biased' to Make a Light rise in the Center of Louver #1. This Exactly Matches the Decks' curved Roofline, and locks into the Groove Lip. The #1 Louver ends on the Backside, perfectly Straight, and carries that level to the Other 6 Slats.
The Plate goes forward and butts with little clearance,  into the Ceiling, Flush with-in the 'View'.  The Plate will be trimmed to Clear the Hinges, but left too Long to come out of the Opening. Remember...145+ MPH, that's the Fastest I've ever had Her, and there was More to Go. Primer and paint comes Next. The wing goes back on.
Pics to Follow:
Questions?
