My Mangusta has a very high clutch effort. I know Dennis Yogi changed his set-up to a Centerforce. Does anyone know part numbers or have suggestions; another owner once used a McLeod ?
Denis
quote:Some people think that a high value or "racing" pressure plate is better but all you get is a sore foot if you do not have an engine in front of it that requires one. Your engine horsepower, torque, traction availability and use (street or racing), should determine the pressure plate that you need resulting in the lowest possible clutch pedal effort.
quote:Originally posted by Mangusta:
A diaphragm pressure plate that will bolt right up??? I was just at my clutch guy's place on Thurs, and he isn't aware of any diaphragm style assy's that bolt onto a Ford flywheel of old.....so will need to look into this..... I don't think he's a big fan of Centerforce for some reason...... He's what I call the "clutch nazi"..... "No disc for you! Back of the line!"
OK, I found these on the McLeod website. Looks like they have two of them, one with 2500# and one with 1700# of clamping pressure. Two different finger heights...not sure which one is for the GOose, but I would guess the one with...OK I'm not guessing...I have no idea which one is better as I could find no description of what 2.070 @ .300 works out to be...really.
360030 FORD 1975-1985 ; 10" Diaphragm. W/ 10.5" Long Patt. 2.070 @ .300 2504 # 3 1/8 No 10" $215.00
360025 FORD 1975-1985 ; Diaphragm. W/ 10.5" Long Patt 1.880 @ .300 1700 # 3 1/8 No 10" $254.00
Steve
quote:Originally posted by Dick Ruzzin:
I have to go against Dana's experience on the clutch effort with my own. When I got my car it had the original Chevrolet clutch disc and pressure plate for the 327 small block, LT-1.
The clutch was not real heavy.
It was very nicely progressive upon release.
Clutch pedal effort is, for the most part, determined by the pressure plate spring force that has to be overcome by the hydraulic linkage. If you have a pressure plate with stiff springs the pedal will be hard to push.
When I had my engine done five years ago the builders put in a racing clutch that had such stiff springs that the slave cylinder rod bent!
I could hardly drive the car. It has been changed to one that matches the engine horsepower, torque and car weight. It is much lighter and easy to drive now.
To evaluate clutch pedal force/effort you have to know the pressure plate force rating in foot pounds. Color or make of car does not matter.
Also, to repeat, Centerforce told me, over the phone, that their pressure plate mechanism does not in itself diminish required pedal force.
Dick Ruzzin
Dick Ruzzin
