Hi Coz! You want all the Aircraft Filler Caps Possible!? Go to: batinc.net Then 'British american transfer' go for 'aero filler caps' and download the specs on 4-5 different sizes (the size your looking at is the 'Aero 400', and requires extensive milling operations). Their smallest size(6 bolt mount)will fit into the original '74 fuel filler door opening; as seen on Plotkins' Black Pantera, in the latest 'Winter 2004' Pantera International Magazine. The last page has the hose connection funnels and price list.
Hi marlin...
Thanks for getting back to me. I down loaded the catalog and am looking it over.
So the Areo 200 is the smallest and will fit the stock opening. Not bad for 75.00 to 92.00.
In our application, would it be the direct or remote mounting ?
You did a great job on yours Marlin. Very impressive !
You did a great job on yours Marlin. Very impressive ![/QUOTE]Coz, on the Pantera You would use the 'Remote' mounting, which means you are using the funnel and 2" Dia. Hose going to the fuel tank. 'Direct Mounting' just means that the filler cap is mounted directly to the fuel tank, itself. Regards,
That's what I thought, just wanted to be sure and order the right one. Thanks Marlin.
