Hi Marlin...Finally found time to install the fans! They work great! Now what do I need to do to have the motor shut off with the key?...Curt
Originally posted by MARLIN JACK:
LOOK CLOSELY! IF YOU PURCHASED THE FAN MOTORS AND BLADES FROM "HALL", AS I DID, THEN YOU SHOULD HAVE THE EIGHT BLADED FANS WITH ALL OF THE BLADES CONNECTED WITH A "RING" AROUND THEM! THIS IS YOUR "BUILT-IN" SHROUD!! YOUR OLD SHROUDS ARE NOT TO BE USED! THIS MAKES FOR A MUCH CLEANER LOOKING INSTALLATION. MY FAN BLADES ALSO, JUST BEARLY CLEAR THE RADIATER, ABOUT 3/16", BUT THEY NEVER RUB. JUST BE SURE TO TIGHTEN THE MOUNTS UP,(YOU MAY NEED TO SHIM THEM)PROPERLY, WHEN ALIGNED. ONE MORE POINT I FOUND!!- THE LITTLE SET SCREWS THAT SECURE THE BLADES TO THE MOTOR SHAFT, YOU CAN NOT GET THEM TIGHT ENOUGH TO KEEP THEM FROM SLIPPING ON THE SHAFT!(EVEN WITH THE "FLAT" GROUND ONTO THE SHAFT). I TOOK OUT THE SET SCREWS AND REPLACED THEM WITH A SHORT ALLEN HEAD BOLT! THIS ALLOWS YOU TO USE OF A LARGER ALLEN WRENCH, THEREFORE YOU CAN TORQUE THEM MUCH TIGHTER. I HAVE NOT HAD THEM COME LOOSE YET! GOOD-LUCK WITH IT, MARLIN.
