I am having all NEW tubular control arms made. The first ones that will be finished will be the Rear Lowers. The price will be around $200 each.
I am also going to have several sets of the Fronts (uppers and lowers) made. These will take STANDARD American Ball Joints, that sell for around $15 each. The price for these will be about $90-100 each, plus the ball joints and rod ends.
The control arms will be made from 4130 C/M tubing that will be heat treated/stress relieved...
I'll have more info later after the first sets are finished in about a week or two...
$100 would be a bare piece. The fabricator said that it would be approx 1-1/2 hours labor, at $55/hour, plus material for each unit. Which I thought was fair. It may be less if I ordered 10 of each, but I don't have that kind of money.
As far as the upper rear, I am going to have some made, but I was going to use an American type ball joint, and fixed rear ends. I don't think you need the adjustment on that arm, since you can adjust the lower to get your camber. I have seen them before and that was how they were made. What do you do about the bolt thru the tapered hole, with the heim joint?
I am interested in a set. Please contact me. Tom Kuestr
I am interested in purchasing a set please contact me at cliff_m_b@yahoo.com
