Today,I installed a set of NOS Grp 4 lights. Strangely, I have no back up lights. I have brake lights, tail lights and turn signals , so I assume it is not a ground issue. I am embarrassed to say I am not sure if I had back up lights with my old tail lights. I removed
the back up light switch and the plunger seems fine. I tried the back up light switch out of the ZF and still had no back up lights with the plunger depressed.
Any thoughts ? Or do I need to get a new back up light switch ? If so who might have them and at what cost ?
Thanks.
First, you really need to determine if there is voltage coming off, or even going to, the back up switch. Then find out if it is making it to the wiring harness at the tail light housings. Get a test light, or voltmeter and find out.
Sometimes the lamp sockets, while appearing solidly mounted in the metal strap that runs the full width on the back of the housing, develop a corrosion that prevents the grounding portion of the circuit from getting to the lamp. This is an internal corrosion and may not be readily visible. Take an ohm meter and check for continuity between the strap and the socket.
If not there, try twisting the socket to break free from the corrosion. Second technique would be to use a sharp awl or center punch and hammer some indentations in the socket ring, where it is crimped into the strap. Use a proper size socket to provide a back-up so you don't damage the plastic housing.
Try these tricks before spending money on a switch that you may not even need.
...Test the Back-Up lights by 'jumpering' the two wires that go to the switch. REMEMBER!!! some Panteras must have the ignition key in the 'Run' position for different lighting to work. I also believe (in RARE cases) that You may need to have the 'Headlight' switch ON, before the Back-Up lights will work. Check it out! And good-Luck! Let us know what you find out...
Today, I checked for power at the inside of the switch. The test light indicated that I have power inside the switch with the plunger depressed. I next checked for power inside the back up light socket and found no power. The test light should come on with the test light needle against the contact inside the socket with the plunger depressed right ?
I do not think I have a corrosion issue as these are NOS units. All contacts are bright and shiny. Turn indicators, brake lights and tail lights are working fine on both sides.
Any new ideas ?
Yes.
Test again and make sure igniton is on. Then test again and make sure lights are on.
Corrosion issue is between the ground contact of the socket to the metal strap which leads to the mounting stud where ground is landed.
...I'am getting the feeling that the Ground is bad! Did you ground your test light to the chassis? OR the ground 'IN' the socket?? If you grounded in the socket; then try it to the chassis. The back-up light 'Ground wire' grounds at two different studs at the rear tail bulkhesd, at least on the '74, they do...
Am I correct that the test light would not work without a proper ground ? If I did not have a proper ground at the studs is it possible for the other lights to work ?
Test light needs ground.
GRP 4 lights only ground at the one mounting stud. If you have some lights working then they have a ground and thus you will have all lights grounded, as the ground gets to all sockets through the flat metal piece all the sockets mount to. And YES, as I wrote very early on, a fine looking socket could have corrosion issues blocking the ground - but this is highly unlikely for only BOTH backups to have that problem.
Carello and Altissimo light plugs are wired the same, whether stock or GRP 4. Unplug the stock, plug in the GRP 4 and everything should be fine.
Have you taken a stock light and remounted it to see if IT had a backup light?
Remember, just plugging it in will not be enough, you will have to mount it and make sure it has a ground. I think this is the next step you should take.
Have you taken a KNOWN good bulb and swapped it for a back up bulb? Your back up and yellow signal bulbs are the same.
Stay with it and you'll find the problem. You won't need a three foot breaker bar, get your hands all greasy or have to remove the engine. Electrical problems are not hard, just time consuming.
Do you have, or can you borrow, a multimeter/voltmeter? Or a continuity tester?
If you want talk this out, I'm home all weekend. California, 559-281-3497
Just one more thought. Could I have a bad connection at the fuse box? Which fuse holder on a 72 Pre L and color wire ?
Swap in an old bucket. Then let's see what we have to deal with.
You can get a cheap meter at Harbor Freight and I'll talk you through the testing methods. Continuity or ohm meter would tell if we had a corrosion issue or open wire.
Nothing but time and measured steps of troubleshooting.
...OK here's the last word I have to help you! I studied the wire schematics that work exact with My '74. 1) A (aprox.) 10 gage RED wire comes off the Positive terminal of the Battery, goes through the front bulkhead to the AMP gauge. 2) From the AMP guage comes a BLACK wire that splits off into 4 PINK wires. Don't get confused!! The only PINK wire You have to be concerned with, is the One that terminates at the Ignition Switch. Yes! This is supplying The Ignition Switch with 12 Volts DC. 3) From the Ignition Switch, when at the 'RUN' position, comes a RED wire that supplys power to FUSE #11 at THAT point there is a 'JUMPER' (brass bar) that also SHARES this 12 Volts with FUSE #12, this IS the fuse Your concerned with! 4) Off the other end of FUSE #12, comes a GREEN wire that travels straight back through the FIREWALL on the Passenger side, and near the wheelwell; goes through a Plastic 'Multi Contact' PLUG, (THIS may be A source of Your Problem. As corrosion here is inevitable!). That GREEN wire, after the Plug Connection, Continues GREEN all the way to the ZF Transaxle To the 'Back-Up Light' SWITCH!! 5) There should be 12 Volts here when the Key is 'ON'. 6) From that same switch, comes a WHITE Wire, to the 'HOT' contact of BOTH B.U. Light Sockets. (The wire was split on the drivers side). 7) From BOTH sockets goes a BLACK wire directly to ground at the STUD in the center of the Rear Tail Bulkhead. In fact ALL the BLACK wires in the 'Rear Wire Bundle' go to ground. That completes the curcuit; PROVIDED Your Battery is Grounded to the chassis in the first place!!! I asked you if you 'Shorted' the Back-Up switch to Test it as being Good! I have not heard an answer. This gives You a couple more things to check out, and is all the help I have for you. Check for 12 Volts at that 'multi contact' PLUG, and AT the BACK-UP SWITCH. Make certain that the GROUNDS 'IN' Light BUCKETS are GROUNDED, as Larry F. pointed out. Lets get these Lights fixed!! And then get back to us!...
Wow Marlin !, Thanks for your research and detailed wiring analysis. I am not sure if this answers your question, but please bare with the electrically/mechanically challenged. I used my test light on the switch at the outside terminal and after removing the cover and cleaning up the inside contacts. I did have power on both inside contacts with the plunger depressed. Are you asking me to try the contact with the white wire outside terminal ?
I will also confirm my center ground. I was under the impression that all rear lights grounded at the two studs on the housing.
Last I will reinstall one of my old light assemblies and see if I had back up lights. I have been told that some assemblies had different contact pin placement such as Euros with the lower amber lens.
Thanks again, to all for your suggestions.
Jeff
Well, the mystery continues ………………….
Tonight I tried the following. With the ignition on, lights on, car in reverse the test light indicates power on both sides of the switch. I found a plastic connector with two black wires (mid rear) pulled out of the connector . Repaired and re tested , but I think this is for the AC condenser fan motor. Next I found another set of two black wires factory spliced together attached to nothing. I thought for sure this must be the ground needed for the back up lights. Nope still nothing. Next I re installed the original left tail light assembly . Still nothing. I tried my test light on the two white wires as they go into the connector. I have power on one but not the other. This is really becoming one of those me against Tony challenges. Probably does not matter much I have been driving around for 12 years apparently with no back up lights. I have brake , tail and turn lights which are the critical ones. Again thanks to all for the suggestions.
Jeff,
I believe (not positive) that all of the lamp sockets in each lamp housing share a common ground (a grounding strap), so if the running & brake lights are working, this indicates it is not a ground problem.
You've mentioned several times that with the trans in reverse you have power on both sides of the reverse switch. This tells me 2 things, your fuse is OK and the switch is OK. Lets move on.
With the key on & the trans in reverse, just the way you tested the back up switch, make sure your test light is grounded very well, using it's pointed end, pierce the insulation of the wire going to the back up lamps at the socket, do you have voltage there?
If not, you either have a broken wire between the back up switch and the lights, OR the wrong wire.
George
George, just a thought, do you have the back-up switch screwed in far enough? The switch is threaded and has a lock nut on it. I know you can thread it in too far and it will actually prevent you from going into reverse, perhaps you have the opposite situation, where the detent is not pushing the plunger into the switch to make the contact.
Gary #06984
George,
There are two white wires going into the connector that connects to the light housing. I have power on one white wire , but not the other. I assume that the second wire is the one that runs over to the passenger side light. It appears I have a disconnect in the connection between the light housing coupling and the coupling from the wiring harness.
Jeff,
I think you're homing in on the problem. the connector on the drivers side, with two white wires, seems to be the problem. The "hot" wire is not conducting electricity to the connector or the second white wire.
Buy a new connector, cut & strip the wires back, twist the wires together, stick them in the new connector and crimp the connector.
good luck my friend, George
Well I finally beat Tony. At least this time. George was correct, the ancient 30+ year old female end inside the nylon connector was bad.
After congratulating myself on beating Tony,I buttoned everything back up and checked one last time that everything was working correctly. What the heck, now no left tail light. I took the test light to the tail light socket and no power. Must be a fuse, simple enough. But the fuses look fine. Switch a couple around still nothing. Tony is back and laughing like hell. Than I remember that these finely engineered ceramic fuses can look intact and still be bad. No problem I have the mandatory extra fuses. Well everything but 8 amp. A quick trip up to NAPA and they actually had the old style ceramic fuses.
(Made in Taiwan, how did China miss out on this one?) I replaced all of the 8 amp fuses and all lights in every combination are now working .
I won this round but I do not think anyone ever really beats Tony. Tony and his cousins live in all of our cars and I would not have it any other way.
Good luck to all !
