I have the 6A box # 6200, Tach adapter #8920, 8350 R2R dist, and a blaster 2... The MSD documentation on page seven, figure 13 calls for the orange dist wire to connect to the WHT wire from 6A box. The only white wire on my 6A is going to my tach adapter?.. I hooked them both together and no spark?.. I think 4NFORD has this same set up?.. At this point I may just remove the 6A and just run the dist alone..??.. Any help or advice would be much appreciated. Thanks...
