I recently upgraded the front signal lights of my Pantera to the LED units produced by Jon Hass of Pantera Electronics.
These amazing lights are easy to install in under two hours and do not require any non-reversible changes to the housings. Simply remove the original bulb and wire section from the light housing, drop in the LED boards, wire-up (match the colors of the new wires to your stock wiring) and you're pretty much done. Remember to buy (from PE or another vendor) the clear lenses to replace the factory amber plastic units.
The LED light boards add (you do need to run a feed wire to the fuse box) a nifty daytime running light feature (very bright white LEDs) that change to amber when the headlights (or just the parking lights) are turned on. When the signal flashers are activated the amber lights (or daytime white lights) flash to a very high-intensity amber. Very clear installation and wiring instructions are provided with the boards. Fit and quality is excellent — as is the value. Highly recommended.
I posted a video that hopefully shows the effects. Note that when the headlights are turned on the lights seem to be washed-out and rather weak, but they are extremely bright and MUCH brighter than the stock bulbs are. Thanks to Jon for a great product!
http://youtu.be/ZXDMgswNPps
Mark
