Hi all...going through all the post regards radiators and placements. Definately a lot of info. My question is, has anyone used the fluidyne rad with two sucker fans and had it fit in the OEM location? I like the idea of sucker fans as opposed to pushers, however I don't wish to go through the exercise of modifying things to lay the rad forward. Any info as always is appreciated.
Thin fans, like the Spal "medium air flow" fans, 11 inches in diameter, mounted low enough on the radiator to miss the headlight bar (not centered) should allow the radiator to stand upright in the oem position. The Spal "high air flow fans" are too thick, they'll hit the forward bulkhead. To use the Spal fans you would have to fabricate a fan shroud, or install them without a shroud on metal straps. Remember the fans need to be spaced about 1/2 inch to 1 inch away from the core.
I haven't actually done this myself (I decided to keep the fans in the OEM position), but I did size things up, I spent a lot of time looking at the options a person may have. I had both sets of Spal fans on hand, but I didn't have the Flex-a-lite kit people generally use with the Fluidyne rad. But since the Flex-a-lite kit centers the fans on the fan shroud, I doubt that the radiator could stand upright with the Flex-a-lite kit (the fans will hit the head light bar).
-G
It will clear on the '72 and later. The '71 needs a little massaging of the fan shroud due to the center support bracket for the headlight bar.
John
Didn't realise you had to do any mods to lay the radiator down.
I have a fluidyne rad with spal sucker fans. I did make a SS shroud for it but to lay it down was two straps that i got from Bob Byers with the radiator so bolted them to the rad, and the other end to the original holes job done, you may require a bit longer radiator hose. you just won't be able to run the original fans in place.
I have left the original fan mounts in the car in case at a later date someone wishes to restore to original.
  • IMG_2137
Chris...that is exactly the information I'm looking for. Thanks so much for the post. Who is bob byers and where do I get these "straps"...love this forumSmiler)
