I have all new parts in my Longchamp's rear end. I'm not sure how to get the right gap or preload on the new wheel bearings. Googling for Jag rear ends state everything from
-0.002" to 0.002"
to
0.006", plus or minus 0.002"
I have tools to measure gap but not preload, and it's adjusted by machining a spacer, not by tightening a nut, so I don't have too much room for experimenting.
Does anybody know specs for Longchamp/Deauville, or at least a general number that normally works? I'm tempted to aim for 0.002" gap, but would like your input.
Hey Mikael,
In 2006 I wrote a little story about a rear suspension fix on my Deauville. You will find it on the Swedish Club webpage.
I did not have anything from the factory either. Chose a preload near whats normal for a standard GM rear axle pinion bearing. Mine ended at 0,5 Nm resistance. It's better starting low, no problem increasing preload but almost impossible to lower it without destroying the bearing.
